alfredo,
Well, the advance mechanism should not move at all as it is held tightly on the cam shaft. I think you mean the slotted disc thingme on the end of the advance rod?
Remove the rod and test fit the PAMCO rotor on the end of the rod to be sure it is flush up against the rod. Could be some manufacturing burrs on the rotor that prevents it from going flush up against the rod.
The normal end play movement for a stock OEM rod is .5 mm. MikesXS rods have an end play of 1mm. Both of these numbers are fine and will not cause a problem, but if it really bothers you, I can send you a special .5mm shim washer to reduce the MikesXS rod end play to .5mm, but do not use the shim on a stock OEM rod as it will cause the rod to bind.
