What was the voltage on the red wire between the E-advancer and sensor plate. Should be 5 volts.
With the Constant sparking it may be a bad part on the sensor plate or a bad part in the e-advancer.
I don't fully understand all the circuitry in the e-advancer. On the sensor plate is a hall effect transistor that is turned on or off as the magnets in the rotor pass by it. The 5 volts to the sensor plate is applied to the Hall Effect transistor. As the magnets turn it on this 5 volts passes through the Hall effect and is sent to trigger the main power transistor in the E-advancer.
If the Hall effect transistor went bad it could have caused the constant spark and when you turned power of and back on it may have finished it off.
Or perhaps the E-advancer had a bad part that caused the same thing.
I think we need to contact Pete on this one.
I'll contact him to relay the info you gave me. You can PM him too.
