ccline746pk
I have a few questions about Pamco ignition systems. I am considering installing one on my 79 xs650 (750 kit, kick start only) that currently runs points and a stock charging system with full size battery (that apears to be working fine).
My questions are:
1. Do you know of any installations of a Pamco on a XS650 that is using heated riding gear (running on the bikes stock charging system),
2. And is there any reason to believe heated gear would interfere with the Pamco ignition system?
I have a jacket and gloves that I used to run on my 83 XS400. I would have to turn down the heat at stops to keep the voltage up but other than that it worked fine.
3. And lastly, for those who have installed a Pamco did you see an increase in MPG and if so how much?
My questions are:
