While it's running, you can gently pull-up on that left carb cable to get an idea of how well the left side is pulling...
it may run strong but that has very little to do with the idle settings .
If your right cylinder is running on a weak mixture which it seems to be then that will impact your left cylinder ,if that one is struggling to fire properly due to oil fouling .
I appreciate that you might not see the relationship but you cannot just look at the left cylinder in isolation .
