ANLAF
XS650 Guru
Fellers
I found the source of my burnt-out battery and regulator-rectifier - it turns out that the source of the problem was the PMA. Symptoms - 15.4-16+v measured with wired-in voltmeter and multimeter. Diagnosis - regulator part of the regulator-rectifier not working.
I exchanged emails with Hugh and sent him pics (I have a Hugh's Handbuilt PMA and reg-rec combo). Hugh said he would send me a replacement reg-rec, but I wondered why the regulator failed if there was anything else I could do to check the PMA because the ohms readings at the plug tested with the multimeter only gave one reading of three (should have three consistent readings). Hugh suggested I pull the PMA and check the soldered connections from the three wires to the copper of the coils. Yes - there was the source of the problem, one connection completely separated. Some soldering was done, PMA refitted but it fired-up only on the battery - there was no charge going to the battery at all from the charging system (multimeter across battery terminals).
I got back to Hugh but I haven't got a response in over a week. Does anyone know if he is away.
HELP! - Has anyone any idea if I can do to anything to fix the bike? I'm desperate to get Back on the road.
ANLAF
ANLAF
