Your stored values are a duplicate of mine?Added another line like you show and....
8000 at line 24 and 30 at line 28?
Correct. Also made sure "legal rev limiter" was off, but I never touched that setting before. It seems to fire right up and revs strong with no misses. Will button it up and take it for a ride tomorrow...Your stored values are a duplicate of mine?
Left of the drain is greater than 40°. That's "melt the pistons" territory.Full advance of 38 at 3000 RPM is just at the left drain groove,
Yep. Double check the pins after plugged - cheap-ass things sometimes want to back out of the block.JP, the connector you put on this box... is that plug and play with the '80 SG?
Middle of the drain slot is 37°-ishfalling right in the middle of the drain grove.
It'll be interesting to see if Jim gets that issue; I think he has a relay that cuts power to the brushes on e-start??I am noticing, though, even with a full charge, it doesn't fire right up with e-leg, but kick start it fires right up.
Yeah, that relay is a great idea regardless of the ignition. Need to do that mod!It'll be interesting to see if Jim gets that issue; I think he has a relay that cuts power to the brushes on e-start??
Oddly, I don't recall the starter cranking long at all - even though it was apparently way out of time.
Yes I do. Be interesting to see if that makes a difference.It'll be interesting to see if Jim gets that issue; I think he has a relay that cuts power to the brushes on e-start??
Will do.Let us know if you experience the same @Jim, once you get it installed on your SG.
Probably not the most elegant solution, but you could run an 8k and a 5-6k resistor through a relay that's energized by the starter circuit. The 8k resistor passes through the normally closed contacts. Put a 5-6k resistor in the normally open circuit. When the starter solenoid is engaged, the 12v to the starter also goes to the relay, energizes the 5-6k circuit and kicks up the bias voltage to the pickup.I presume the e-start drain so much that the battery voltage drop down and we haven't the polarization through the 8k resistor right.
Lemme come back with a mod....
