there are a few tricks to drum brakes. 1 loosen the axle, apply brake and tighten axle with brake still on, this will keep the drum centered. 2 the drum will work best if the actuator on the brake is at 90¤ when the brakes are applied. you may need to rotate a few splines. 3 new shoes can take a while to bed in, what kind of shape was your drum in? 4 linkages as mentioned need to be just right. a small change can mean a lot. cheers
Posted via Mobile
