nb1914
Hi All,
I have ordered a new swing arm bolt and sleeve with brass bushes . I tried a dry assembly on the table and found that it appears as though the bolt won't fit in the sleeve potentially, i say potentially because I'm not sure how tight a fit this should be. The threaded end fits in upto the end of the thread, also the brass bushes are what would appear to be an interference fit on the outer sleeve. should all these parts fit together freely or is it required to put some force into it ? its possible that on the inner bolt that a lip has built up at the end of the thread that needs filing but just after some advice on how these parts should fit and whether its usual that some refinements are required.
