Nah, TwoMany, John Customer doesn't think you owe him a living, he just thinks you don't need to make one! These guys bring a neglected barn bike in, say "Just get it running," expect a full refurb job, and want to pay south of $100--"But I only paid $200 for it!"
I'm comfortably retired, but one local indie shop occasionally calls me in on problem XS650's. The last one I worked on was a real gem. This clown had done a hardtail bobber, and he and his buddy--a "certified motorsports technician"--had pulled the motor to paint the frame. They had 12V everywhere it needed to be, but couldn't get spark. I asked the shop owner if the bike still had breaker point ignition. It did. I told him "OK, they painted over the condenser ground. You can fix it and charge $25, then have the fool blame you when he blows it up, or you can have me go through it, fix what needs fixing, and write up a condition report that covers your butt."
Checked compression first--no point spending money on a bad motor. Timing was set with full retard at around 5* BTDC and full advance around 45*, so bobweights had to be modified; the owner was headed for a holed piston. The goofs had hung the carbs in boots that had all the stiffness of firm foam rubber (we know where those come from), and on top of that he'd left the metal shrouds off. We didn't have replacements, so I wrote the problem up in the report to the owner. The battery ground cable had been replaced by a piece of 12 ga. wire--a custom touch, I guess.
I forget the rest of the flaws I fixed, but there were several. The bike went out with ignition recurved and strobed in, carbs synched, proper ground cable, and notes on defects. I gave two copies of the report to the shop owner, and told him to give one to the customer and have him sign the shop's copy. The tab was $250 to the shop. The owner didn't quibble, and the POS didn't come back.
