Safe to run as is or do I need to DA the braking surface? It was blasted with black diamond 30/60 fine grit. You can still feel the ridges in the rotor.
Don't go to 3/8" the hole size should not exceed the thickness of the disc. I did .220" diameter holes. Something like 84 holes. Lost almost 4 ounces of weight. Worthwhile for the reasons listed above, and keeps your pads cleaner too.
