pyrocentric
- Messages
- 221
- Reaction score
- 1
- Points
- 18
I'm toying with the idea of converting to manual spark advance to get a better understanding of how it works. Having sprained an ankle kickstarting the XS last year before I knew better I'm aware of the risks , and I probably won't follow through, but I'd at least like to know a little about it.
From what I've read, it seems(correct me if I'm wrong) to start the old harley's you twist the left grip all the way forward to retard it, kick it, then once it's started you turn the grip towards you to advance it full and leave it there while it's running. Many of them use a spring to hold it at full advance. Some say they retard it a bit going up hills(I guess they heard the pinging?) when the engine is lugging. I assume the vacuum advances in cars did the same thing...retard the timing when the engine is under load.
The XS is similar, full advance at 3000rpms and keeps it there. Of course at idle it drops back to full retard to avoid igniting too early while the piston is still coming up. I assume the theory is instead of retarding the advance and lugging the motor on hills, you just downshift and let it scream at higher rpms in the powerband.
Anyway, just wanting to learn something new. Would there be any benefit to a better advance mechanism, manual or otherwise?
