simplified wiring double checking
urbandork
So I plan on not running a high beam since i dont use a head light stay and can pivot the head light up and down on command. Im also going with a HID bulb which should be super bright anyway.
Im doing this so i can use the Hi/Lo switch as an on and off switch for the running lights and stuff. This would allow me to kick start the bike with out the lights on as doing it with the small 0.8 AH bat isnt the easiest thing to do. (I would rather not add another switch)
Im also only using the front brake switch as the rear one got removed when i took off the passenger peg/muffler hanger mounts
Any how this is what ive drawn up so far... I am using a green monster coil and pamco ignition along with a perm mag alt and a solid state reg/rect.
thanks in advance
oh and this is a pic of the bike so far... still have to do the seat pan part and straighten out the bottom of the hump
use an on-off-on switch as a lo-off-high. high beams come in handy if the low beam burns out in the middle of nowhere.
