anthonywanderedaway
XS650 New Member
Hey all, this is my first post here, thanks for having such a great resource for xs650's!
I recently bought a '78 650 Special and have been happily riding for about a week now. The other day I went on an 80-mile ride with no issues, but on the very last mile before I got home, the right cylinder began to cut out and I barely made it home. Lots of gas was was leaking from the airbox and the plug was wet with gas also.
Some forum searches led me to diagnose it as a stuck carb float causing the float bowl to overflow. I removed the float bowl and float, checked that the float didn't have any leaks, and reinstalled the float bowl.
Tried starting, same issue with gas in the airbox.
Would adjusting float level be the next step? I initially didn't go that route because the problem popped up suddenly and it didn't make sense to me that the metal float tang would suddenly go out of adjustment so radically.
Are there any other possible causes for this problem?
The petcock on that side is also leaking some gas. Would a faulty petcock lead to this problem as well?
By the way, the bike has the stock BS38 carbs and vacuum petcocks.
Thanks in advance for helping!
