Stickysteve44
Noticed a lot of bluing on the left side header. My ir thermometer says it's running about 30-50 degrees hotter. About to sync carbs and adjust mix screws. Fortunately a previous owner removed the plugs over my mix screws. That's pretty exciting as I was worried I'd drill in to the screw trying to remove them.
Anyways, it came with bp8 plugs which seemed to be fouled and a bit cold. The bp7's I put in seem to be too hot. Should I switch back to the bp8's or stay with 7's
Top pic is 8 bottom is 7. Left cylinder on left, right on right.
I obviously need to sync and adjust mix first.
