xjwmx, the Porsche elephant foot adjuster are flat where they contact the valve stem. The center of the foot hits just off center like the stock adjuster does and it may not turn the valve as much but I think it still turns the valve.
It looks like the flat foot on a C-clamp. The flat foot has a ball and socket connection with the adjuster screw. This ball and socket fill with oil and this dampens the noise a bit.
The flat surface of the adjuster and the flat surface of the stem makes getting precise clearances easier.
The increase in surface area where the flat on the adjuster contacts the stem decreases the wear dramatically. The ball and socket has a much larger contact surface than the stock adjuster to stem, so the wear on the adjuster is decreased dramatically. This decrease in wear means you have to adjust much less often.
So more precise adjustments done much less often sounds like a win win situation.
To use them you need to mod the rocker arm a bit. This may weaken the rocker arm a bit but I think it was way over built to start with.
