EvenmoreXS
1981 XS650
Things are getting better. Im now trying to get even pull through all rpm ranges. Pulls ok early, not too bad, flattens out midrange regardless of gear, once rpms hit a point pulling resumes. Pulls ok if I bypass that rpm range......go a little faster in 1st gear and change at a higher rpm. Not my typical riding style, not trying to win any races,,,,except the ones with the 5.0 ... Just looking for even pull throughout. I think its carb related. I have 2 new main jets ordered. I think its lean in the midrange. My best guess. Ive seen a few slipping clutch comments....could be i guess, but I dont think so. Here is a quote i found here on the site....
- 2. Midrange (full throttle /2500 to 3500 rpm)
Step 1 (Best Main Jet) must be selected before starting step 2!
Select best needle clip position
o To get the best power at full throttle / 2500-3500 rpm, adjust the needle height, after you have already selected the best main jet.
If the engine pulls better or is smoother at full throttle/2500-3500 rpm in a full throttle roll-on starting at <1500 rpm when cool but soft and/or rough when at full operating temperature, it is too rich in the midrange and the needle should be lowered.
If the engine pulls better when fully warmed up but still not great between 2500-3500, try raising the needle to richen 2500-3500 rpm.
If the engine pulls equally well between 2500-3500 rpm when cooler as compared to fully warmed up, the needle height is probably properly set.
Do not pay too much attention to the low-end richness when you are changing needle clip positions - you still need to be using the clip position that produces the best full throttle / 5k-7k power in conjunction with the main jets (Step 1) that produce the best power at high rpm. You will deal with the low-end / cruise next.
Because it pulls well at high rpms, i think the needle is ok.????
Pulls fine at low rpms, pilot should be ok?????
Weak midrange.........size up the Main jet???
Going to open pipes with baffles soon, running a 2 into 1 now.
Opinions on how to get my midrange back. Am i on the right track?
