Right, 150 lbs. isn't high compression. OP, you've listed mains and pilots. Now what slides, needle jets, and needles are you using and what air jet, if any, is in place?
If fuel level is a bit too high you could be getting a rich condition when fuel sloshes forward due to weight transfer under hard engine braking, and the fact that symptoms are worse on downhills is consistent with that possibility. Here's a way to check. On a downhill grade, disengage the clutch, let the motor idle, and apply the front brake firmly. If the motor stalls or rpms drop sharply, fuel level is a bit too high. Raise the float level a bit and go again. If you need to adjust float level, measure at the point on the actuator arms where they contact the horizontal pins on the floats. Don't touch the actuator tang! Make adjustments by moving the arms.
And yes, this is far off topic and belongs in another thread.
