Will the tire 150/80-16 fit this my stock 16" rear wheel?
BobberNick
SLC, UT
Will the tire 150/80-16 fit this my stock 16" rear mag wheel? The marking I see on my wheel is 16 x 3.00. There is a good deal on a slightly used tire that I would like to get if anyone knows if it will fit my rim. I just don't know enough about tires to pull the trigger on it.
Thanks,
Bobber Nick
It looks like I found a tread telling me it would work. Can anyone confirm that it will fit?
Hears the thread:
- 3.00 x 16...rim, here is an indication of what tyre size is recommended for relevant rim sizes
...tyre..............rim
130/90-16...2.50 - 3.50
140/90-16...2.75 - 3.75
150/80-16...3.00 - 4.00
I guess my questions is, will this fit my stock - hardtail conversion frame? The tire looks pretty wide.
It'll definitely fit the rim although the small rim will pinch it and make it a bit taller. Now for fitting the frame it's a toss-up, not to mention how far are you gonna have to offset the sprockets. I'm thinkin' too much trouble -- not worth the effort.
How tough is is to offset the sprockets? I assume the reac can be done fairly easy with shims. Would I have to purchase a new drive shaft for the front sprocket? I like the size of this new tire. I think it would look really cool on the bike.
im running a kenda 140 rear tire with 520 sprockets. the chain has about a 1/4 inch between the frame (hardtail) and about the same to the tire. just a thought. a narrower chain will give you more room to play with.
Thanks everyone for your help! The tire fit perfectly on my stock rims and the fender I have. I think I'm going to try and sell those wire rims with the sprocket/drum combo.
thanks, Bobber Nick
Actually the 520 chain won't give you any more room between the chain and tire. A 520 sprocket sets against the hub the same as a 530 sprocket. So the 520 has the same clearance as the 530 chain.
A 140 wide tire won't hit the chain. On a swing arm bike it hits the brake strut and swing arm. Unless you gring off some of the chicken strip on each side of the tire.
The ride I have is a hardtail... I need to mount the motor this week. I guess I'll let you all know if the tire fits without having to mod the original sprocket.
To offset the front you need an offset sprocket. No one builds a longer output shaft for the transmission.
