You should have two F marks. The points time so both open between the two marks. Set the Right, upper set first, They are mounted on the full breaker plate. Then set the Left, lower set, they are on a half breaker plate.
The pin holes should be the same size. If you can't get the pin in the other hole on one end of the rod, try the other end. AS long as you get them to match. Getting them to match simplifies thing a bit.
What repair manual do you have? It will tell you the proper procedure to set the gap and timing.
