Leo, could u show a pic of filters or part #? Want to make sure I get the right ones.As fredintoon said those pods suck, pun intended, Those short tapered pleated element pods cause to much turbulence in the air flow through your carbs. This causes a poor vacuum signal for the carb slides. This can cause all sorts of trouble.
Long straight foam filters are a much better option.
Being a chopper I assume you run short open pipes, these lead to tuning issues too.
Have you read www.amckayltd.com/carbguide.pdf ? This is our carb bible. It has a "Tuning for Mods" section. This mat help with your carb issues.
PeteIf that is the "Green Monster" coil from MikesXS part number 17-6810, then it has a tendency to short out internally if you operate the ignition for even a second with one spark plug wire disconnected. For that reason, use of the coil with a PAMCO ignition will void the PAMCO warranty, as stated in the installation instructions.
A better choice would be the 17-6822 or the "Ultimate" 17-6903 coil.
Paul, I answered your PM.Pete
Trying to contact you about warranty on ignition?? What do I do to get thing started??
