Finally getting things finished up here on my XS1, and hoping to get it ready to pass NYS inspection. Everything works except for the headlight and the horn.. With the ignition switch clicked over all the way to the right, the tail light is on in which I would assume the headlight would be on as well? Well, if that is the case, than obviously I have no power running to the light. I put a meter on the headlight bulb socket (green, yellow and black wire) and found no juice running to it. Any suggestions? The horn also doesn't work, but that Is a mechanical issue as I have yet to find a button for the original horn control. Any suggestions as to what I should try next? Blinkers work, tail light, break light works, as well as neutral and blinker indicator light. Thanks in advance for all of your help.
