Thanks. This is what I was looking for.There are several diagrams here in the "Tech" section. Here's one example with your "late model" ignition and charging system
The red/yellow solenoid lead may indicate that your bike inherited a Honda solenoid at some previous point: no matter, it will work. It depends on what key switch style you have. The stock Yamaha wiring used the red/white wire for the positive side of the solenoid coil (Honda used red/yellow). The positive switched wire from the stock key switch would be the brown wire and the blue/white wire supplies the switched ground through the starter button. If you are actuating the starter circuit via a 3 position aftermarket key switch (start pole sometimes labelled 'S') the ground side of the solenoid could be a permanent connection and the red/yellow connected to the 'S' terminal (that's the way the above diagram I posted contemplates)Where on my ignition switch does this red/ yellow starter solenoid
Wire go.
It was connected to the top lug on this switch which is not labeledSpliced to?
This the ignition switch in using nowThe red/yellow solenoid lead may indicate that your bike inherited a Honda solenoid at some previous point: no matter, it will work. It depends on what key switch style you have. The stock Yamaha wiring used the red/white wire for the positive side of the solenoid coil (Honda used red/yellow). The positive switched wire from the stock key switch would be the brown wire and the blue/white wire supplies the switched ground through the starter button. If you are actuating the starter circuit via a 3 position aftermarket key switch (start pole sometimes labelled 'S') the ground side of the solenoid could be a permanent connection and the red/yellow connected to the 'S' terminal (that's the way the above diagram I posted contemplates)
Does that switch have 3 positions: OFF, ON & spring-loaded, momentarily on?This the ignition switch in using now
YessirDoes that switch have 3 positions: OFF, ON & spring-loaded, momentarily on?
What if the switch has only 2 positions?It will then lend itself to actuating the solenoid - if you want to wire it that way. Verify with ohm meter that B (battery) has coninuity to 'ST' when in the momentary position and connect red/yellow there. Then ground the other solenoid lead (green?). When the switch is turned to momentary (ST) , then the solenoid should "click" and connect the two primary lugs connecting the battery to starter motor
No just a black one. Not to sound dumb but what is a switched positive is that the ignition lug or the battery lug or the accessory lug. Thank you.That doesn't work well on a starter circuit that should be momentary switched only. I would then use the original starter button to provide the ground side to the solenoids' coil (is there a green wire along with red/yellow?) and wire the red/yellow to a switched positive from the key switch
