yes I have read thru jJims thread, Its very well done, I do plan on taking skirt to wall measurments and of course making the ring gaps correct with a ring gap file, the skirt to wall clearance right now is .001 to.0015, almost the requred .002 and the rings have no gap to speak of so I will have to gap them myself,
today I cleaned up the bottom end (case) at least on the ouside a little, and removerd the clutch side cover, I couldnt belive how clean it was inside and how nice all the parts looked, Im tempted not to split it and just put the tp end together, But I have a NEW D.I.D. endless cam chain and I dont know if it can be "BROCKEN" to instal, I belive the only way is to split the case and drop the crank so I can put it on, ANYONE chime in about breaking a new chain with a chain breaker??? also If I have to open her up anyways I want to put the 5th gear overdrive in her, 60 bucks for one gear seems like a good idea? here is some photos of the bottom end the last photo has a brand new PBI 18T sprocket on it, I dont know if I will run that, but i had it
again questions im asking yall, can you break a new DID chain with a chain breaker, good idea bad idea??
and any experiance with the 5th gear overdrive?? Ive heard some stuff about the engagment dogs i think??
