Your float level sounds good.Your needle clip position sounds to rich. It should be in the 4th slot from the top for stock. Just to check are you sure they are 75 carbs? I don't think they put the place to hook in barbs in the carb bodies until they linked them in 76. The 75 had two seperate carbs, two throttle cables. One link was the enrichener, it was in the left carb and linked to the right with a hose.
There was a link between the fuel inlets too, a hose.
