Small update: received most of my OEM engine seals yesterday along with some progressive fork springs. Need to order one of Hugh's 2" lowering kits for the forks so I can start rebuilding those and shaving the tubes. I'll likely run a left front brake so I can use the other brembo on the rear caliper.
Did some soda blasting yesterday, got my old BS34's, PWK's and the EX500 carbs all blasted up. Need to finish cleaning them up in the ultrasonic cleaner, then I'll start sourcing some replacement gaskets, seals and other hard parts, probably JBM boots for the BS and EX carbs. Also posted up a sale thread for the BS and PWK carbs, they'll be rebuilt correctly, so check it out if interested.
Mounted the 19" conversion to the wheel and have them primered, but it's been so cold I can't paint anything.
Ordered a 5th OD from a member on here as well.
Also nearly finished with my port cleanup. removed a little material here and there, but didn't get too aggressive. still need to do the final polish on the exhaust ports.
finally need to start cleaning up the fins on the cylinder and head. I'm going to try to clean up all the welding flash and make everything appear as smooth as I can before painting. Should look a little nicer, especially with the polished edges.
