It doesn't take a god to figure out grabbing "a fistfull of brake" is about the worst thing anyone can generally do.
I agree completely with you BUT it is often the case that an automatic reaction takes over. On a dry road you might get away with it but on wet?
Modern (and some older) brakes have good stopping ability and if, as you say, they can overcome a tyre then as the coefficient of friction reduces then that would only compound the situation.
Surely a situation when the rider would benefit from some help?
......modern day electronics are prone to failures too. Even modern 4 wheel vehicles can have ABS failures. I've been there. My 01 Xterra had a sensor failure at 60k that caused the vehicle to stop like it was on ice on dry pavement.
Modern electrics can fail but from my own experience, covering in excess of 44K miles per anum for some thirty years. I never suffered any issues. In all of that time I was rarely aware that there were any electronic aids present.....except onece. ABS came to my rescue and saved me from at best a badly dented car.
Nowadays systems perform function checks not only before moving of but also whilst driving. In the unlikely event of a failure then all the driver will be aware of is that a warning light on the dash has come on.
I have experienced, in controlled situations, the difference between driving with and without ABS, stability controls and the like.
Like many drivers I an a driving God (NOT) so I'll stick with the electronics any day.
I can understand your reluctance to trust electronics having suffered such a problem.
Many, many moons ago I suffered a front brake cable failure when attempting to stop at traffic lights when the cable pulled through the nipple.
I guess we have to accept that from time to time sh*t happens but a one off incident doesn't mean that it will happen to every other one.....does it?
