Like I said, I think the stock front brake on these is pretty good. I probably wouldn't be here writing this now if it wasn't. I've had to panic stop a couple times on mine and it performed admirably. I had that front tire howling, right at the edge of adhesion. Braking doesn't get any better than that. Once you start sliding or skidding, you're screwed. You may think a stronger front brake is what you need/want but if it causes you to lock that front wheel, you're worse off.
I have to think that the engineers at Yamaha had some clue to what they were doing when they chose the brake components, specifically the MC size. Other things they got wrong were changed or updated over the years during the production run but they never changed the MC size. Maybe it's not absolutely the best size but on the other hand, it's not absolutely the worst either.
