Good thought Frederick. ....and where might one get a smaller diameter master cylinder?
Pete
Pete
Hi Pete,Good thought Frederick. ....and where might one get a smaller diameter master cylinder?
Pete
Hi Pete,Very cool info 5T and Fred - thanks so much!
I am going to go DD on the cafe. I've already secured a second disc and I've got an LHS caliper as well. It is still too danged cold out there in the Disaster Central workshop for me so I can't really say what sort of shape the master cylinder is in but it appears to be a bit of a mess. Not to worry, I'll get there. I'll certainly be replacing the hoses with braided and will likely drill the discs too (but not with 20mm holes - even though they look cool ...in a sort of an I don't know what the he!! I'm doing kind of way).
On another front, I had to go to Seattle on business this past week (my own business - don'tcha know...) and while I was there, I had a chance to do a meet-up with Brassneck who created the inspiration for my own bike. All I can say is what a nice guy, what a talented motorcycle craftsman and wow - his bike is even more impressive in-person! He let me sit on it and I learned a couple of useful things:
1) those rear-sets are fairly high;
2) my knees don't go quite that high. ....at least not for long.
3) the clubman bars may be too low for my old back.
So...I'll be doing some mods on the rearsets to bring them down to a place where I can ride comfortably and I may switch over to a simple set of flat handlebars - but I sure do love the look he has created. The paint job on his bike is really beautiful and he sure has that machine sort out nicely.
Anyhow, onward and upward!
Pete
Effects of unsprung weight[edit]
The unsprung weight of a wheel controls a trade-off between a wheel's bump-following ability and its vibration isolation. Bumps and surface imperfections in the road cause tire compression—which induces a force on the unsprung weight. The unsprung weight then responds to this force with movement of its own. The amount of movement, for short bumps, is inversely proportional to the weight - a lighter wheel which readily moves in response to road bumps will have more grip and more constant grip when tracking over an imperfect road. For this reason, lighter wheels are sought especially for high-performance applications. In contrast, a heavier wheel which moves less will not absorb as much vibration; the irregularities of the road surface will transfer to the cabin through the geometry of the suspension and hence ride quality and road noise are thus worse. For longer bumps that the wheels follow, greater unsprung mass causes more energy to be absorbed by the wheels and makes the ride worse.
Pneumatic or elastic tires help by providing some springing for most of the (otherwise) unsprung mass, but the damping that can be included in the tires is limited by considerations of fuel economy and overheating. The shock absorbers, if any, damp the spring motion also and must be less stiff than would optimally damp the wheel bounce. So the wheels execute some vibrations after each bump before coming to rest. On dirt roads and perhaps on some softly paved roads, these motions form small bumps, known as corrugations, washboarding or "corduroy" because they resemble smaller versions of the bumps in roads made of logs. These cause sustained wheel bounce in subsequent vehicles, enlarging the bumps.
High unsprung weight also exacerbates wheel control issues under hard acceleration or braking. If the vehicle does not have adequate wheel location in the vertical plane (such as a rear-wheel drive car with Hotchkiss drive, a live axle supported by simple leaf springs), vertical forces exerted by acceleration or hard braking combined with high unsprung mass can lead to severe wheel hop, compromising traction and steering control.
As mentioned above, there is a positive effect of unsprung mass. High frequency road irregularities, such as the gravel in an asphalt or concrete road surface, are isolated from the body more completely because the tires and springs act as separate filter stages, with the unsprung weight tending to uncouple them. Likewise, sound and vibration isolation is improved (at the expense of handling), in production automobiles, by the use of rubber bushings between the frame and suspension, by any flexibility in the frame or body work, and by the flexibility of the seats.
Hi Marty,Before committing to dual disc front brakes....... The XS1100/XS650 rotor weighs about 7 lbs. The caliper weighs over 2 more. The extra brake is 10 extra pounds of unsprung weight. Most of us are trying to shed extra weight. The XS650 wasn't designed for that much. The Euro and Oceania models had smaller rotors. Will it work? Yes, it will.
From Wikipedia:
Hi Pete,Dang - so many choices.....
I'm pretty up on unsprung weight effects and four piston caliper as I consult for auto firms but, I guess I've been beguiled by the look (does that make me a hipster?) - and my peg scraping days are over. Well, I need to think this through and do a little cypherin' as Jethro Clampett used to say.
Hmmmm.....
Pete
