I scrub it down with kerosene and old paint brushes, or better yet, these chip brushes from HF. Cut the bristles down about half way so they're stiffer. A box will last you for years. Also great for little painting jobs, just throw the brush away when done .....
https://www.harborfreight.com/36-piece-1-in-industrial-grade-chip-brushes-61491.html
Even with a new seal and bushing, the short outer rod in the 2 piece set-up will still wiggle side to side quite a bit. The worm will sort of hold it steady once assembled but still, the back end of it is free to "wander". That's one of the nice things about the long one piece rod, it barely wiggles at all. If you do find your seal is leaking, do the long rod swap first. That may cure the leak if it's not too bad.
I try to get under that left cover once a season and clean it all out, before it gets the chance to get too mucked up. I re-grease everything as shown in my pic above, and oil the clutch cable too. I'm usually not presented with much of a mess because I've managed to seal things up pretty good in there. Mostly, I'm dealing with chain lube fling-off. Here's a "before" pic .....
