Enginerd
Hey Everyone. I have a 75 XS 650 that I've owned since 1996. Due to work circumstances, it hasnt been started since 2010. Now that I have a bit more time, I've decided to build a scrambler. I have purchased another frame and modified it while keeping my original 75 Standard rolling chassis.
Here's my 80 roller that the engine will go into.
I have pulled the engine from the original 75 XS, and I intend to put it into the new frame. But as I mentioned earlier, the engine has not run in 5 years. What should I do to the engine while it is out of the frame to ensure longevity in the years to come?
Here's what I propose so far:
Any other suggestions folks?
Thanks for your help!
- New Cam Chain
- New FRONT and REAR plastic cam chain guides
- New Valve Springs
- Change sump filter and right side filter
- EX500 carbs to replace OEM BS38's
- PMA setup to make a minimalist, clean and reliable system in the new frame. (Engine currently has a Boyer setup up top)
