No voltage on the yellow wire with engine idling is a bad sign for sure. There should be about 7 volts DC or 14 volts AC, when measured from ground.
With engine idling, you need to measure AC voltage across any 2 pairs of the 3 white wires that come from the alternator stator. Measure all 3 combinations. 12.5 to 13 volts AC is normal.
Stator is looking suspect. If you don't get proper AC voltage, next step is to measure the resistance (unplug the connector) between the 3 white wires (stator windings)...........depending on what meter you have, should read about 0.5 ohms to 1.2 ohms. Also measure resistance from any white wire to ground (yellow wire must be disconnected for this test).................should be very high resistance.
