Well I am just about to the point of giving up on this thing. Corrected the short that was blowing my fuse. But before that I put my new stator back on, having seemed to pass the stator tests. No charging, no AC voltage.
Took it back off and put back on my old stator, feeling certain this one would work since as earlier in the thread seen, it was unlikely the initial problem. No blown fuse this time, but still no charging, no AC voltage.
Neither stator configuration passes the slap test. Regulator is fine, rotor is fine, brushes read battery voltage with switch on, yellow wire shows voltage, but there is just no voltage being put out of the alternator.
I am following the testing procedures to the tee and it's just not putting out, everything points to the stator HAS to be grounded because no current but both stators??! I've taken these off and put back on so many times I am becoming obsessed with trying to figure out why they're grounding.
I am really confused and angry in the back of my mind I just want to choke down the loss and install PMA/Pamco but then I think, what if that doesn't work either?? I literally do not understand what the fuck is wrong with this motorcycle. I've had it an entire year and troubles here and there but nothing this extensive. I'm no genius but I'm no dummy either....I resolve issues fairly quickly.
I've been without wheels for an entire month now and this is very bad, it is my only transportation and I can only go so many places within walking distance. In 3 months or so I'm going to have to move and it's difficult to do so without transportation.
Anyways.............I'm calling it a night.
