The reason that your alternator isn't charging the battery is because the rotor is not being earthed ..OK just tried this....
1) Yes.
2) Yes.
3) Can you please clarify? The brush wires connect to the wiring harness.
.You have told us that it has a a 12v supply to the positive stator brush but the rotor is not creating a induction field therefore the rotor is not getting earthed
the black coloured wire that comes from one of the stator brushes should be earthed. If your bike is the later one 80+ then the earthing is done via the regulator. This is clearly not happening for some reason or other
To bypass the regulator you could take a wire off the stator brush that has the black (earth) wire connected to it and take it to an earth point on the bike . By that I mean anywhere on the bike that is connected to the earth terminal on your battery .
Then try the slap test ...it should now work.
ps make sure that if you have removed the brushes to make these tests that you have kept both brushes and black and green leads insulated electrically from the stator body
