TeeCat
One-Mik Wonder
Hi, troop...
Last oil change, I had tried a couple quarts of Valvoline 4-stroke motorcycle oil (dino) in 20W-50, but wanted to go to thinner oil in case I ride any this winter; the 20W-50 is too hard to kick, and may tear my sump strainer, I feared. So, I went with some Valvoline 10W-40 this time. It's motorcycle oil and designed for wet clutches, but all they had was full synthetic. I have never run that before but thought I'd try it, and if I didn't like it for performance reasons, it will have cost me about $16.00 and no harm done.
Well, long story short, the bike seems to really like it, just based on two local outings of about an hour each, in 60-ish F temps. Shifting seems excellent, no discernible clutch slippage, etc. But here's the one thing I really noticed:
I run a single Mikuni VM with a knurled idle speed screw. It does have a slot for a screw driver, but I like it because I can use my fingers to dial in my cold and hot idle easily as the bike warms. Well, this is a very precise thing with my bike. She has "rules", and you must learn and live by the "rules", or you will be reminded of the "rules". The difference between her cold and hot idle is exactly 3/4 turn of that screw, and at warm idle, the slot is horizontal. Well, with the synthetic, I noticed that the warm idle is a few hundred rpm higher, and I have to back the screw out about another 1/8th turn to get her right at 1200 rpm. I wonder if this is a consequence of reduced friction? I don't think the ambient temp is a factor, and this screw setting seems to be a "rule" with her. I don't think it's coincidence.
Very interesting!
TC
Very interesting!
TC
