@xjwmx,
This may interest you.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
The section under "Drawbacks of viscosity improving additives" explains why I start using oil after 900 - 1000 miles (imo)
You might also note the temp for viscosity is 210 degrees.
My motors are running above that. Soooooooo the higher weight/viscosity isn't really what the bottle says. The higher the temps the thinner the oil.
@XSLeo,
I really enjoyed the gravel analogy.
When I patch the drive I don't put in pea gravel. It simply won't hold. The next rain will have it all back in the creek.
If I use crusher run (everything under a certain screen size) the different sizes help hold it in place.
Thinking of it this way. Wouldn't different size molecules hold in the crevices of the cylinder walls better? Again these weren't built with tight tolerances the modern oils are developed for.
@XSLeo,
