1. Dismiss Notice
    Dismiss Notice
It's past time to start XS2 Resurrection
Discussion in 'The Garage' started by GLJ, Oct 31, 2018.
  1. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    TwoManyXS1Bs, Jim, Mailman and 3 others like this.
  2. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    Thanks Skull. Very Interesting.
    Jim, Mailman and gggGary like this.
  3. GLJ
    Decided to use a somewhat local welding shop for the case repair. Dropped the case off Tuesday and they called today saying it was done. So went and picked it up. Looks much better than I could have done. He said he V'd the crack and welded it on both sides. I think it looks good. Can't leak any worse than it did. Now I can do final cleanup on cases and start reassembly. Also drop off the upper end parts at machine shop for the work that they need.
  4. GLJ
    Things slowed down a bit as I had to go out of town for 10 days. Finally got the engine cases cleaned up some. I'm thinking of leaving the lower half " au naturel".
    The upper case is almost cleaned up. It will get painted with POR-15.
    Question for Jim or anybody else that has used POR-15. What is the best way to prep the case? I ordered their metal prep for aluminum AP-120. Is their something better? I read where it brushes on very well, that is how I plan on putting it on.
    The lump is looking better.
    Mailman, MaxPete and Jim like this.
  5. Jim
    I use Alumiprep 33, but that's just 'cause I have a few gallons left from my airplane days. :rolleyes: The AP-120 should work just fine. All you're expecting from it is a good acid wash to remove any contaminates (oil, grease etc.).
    I'm pretty happy with the POR-15... with one caveat... the silver dried to a dull gloss. It actually looks exactly like the factory paint however, I wanted a high gloss. On my next engine, I'll top that with a good 2 part epoxy or urethane clear.
    MrBultaco and MaxPete like this.
  6. GLJ
    Thanks Jim!
    Factory is what I am after.
  7. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Looks really nice and I agree, the welding looks good.
    I had a ‘75 B back in the day and I had a master link fail which cracked the case (thinking about it now, I was lucky it didn’t lock up the rear wheel and toss me over the bars). I had it welded and after a little while, I never even noticed it anymore.
    Pete
    Jim and GLJ like this.
  8. Jim
    I use a spray bottle.... old Windex bottle or sumpin like that.
    MaxPete likes this.
  9. GLJ
    For the prep or the paint?
    I was referring to the paint. My bad I phrased my post badly.
    Jim likes this.
  10. Mailman
    Lookin good buddy! I want to see how that paint turns out. I don’t remember, is it your intent to keep this motor as a spare, or are you going to install it as soon as you’re done?
    Jim likes this.
  11. 650Skull
    This was posted the other day........How they strengthened the club racer, (i mentioned how they had the same problem), mount on the case.
    http://www.xs650.org.au/Club Racer Stuff/club racer report 2019/club_racer_report_2019.htm
    Honestly i think the guy welding should have suggested strengthening that area.........
  12. GLJ
    You could be right.
    I'm not going to ride it as hard as I did 35 years ago. If it doesn't leak oil I'll be happy.
    Mailman and Jim like this.
  13. GLJ
    Getting ready to change the rear sprocket from a 38 tooth to a 34 tooth. No more racing Sportys.
    The 38 makes the bike very quick, trouble is if you grab a hand full of throttle shifting it is like playing footsies with a bobcat.
    Reminded me of riding a 125 Elsinore.
    Also got stuff coming to get the original tank back on.
  14. Moabite
    Moabite XS650 Addict Top Contributor
    Look at all them trophies...
    gggGary, GLJ and Jim like this.
  15. GLJ
    Ultimate goal is to get original engine back in and running.
    MaxPete, Moabite, Jim and 2 others like this.
  16. GLJ
    Most but not all. Days of future past.
    MaxPete, TwoManyXS1Bs, Jim and 2 others like this.
  17. Mailman
    By the way, your bike is looking pretty shiny there. Looks like you’ve been doing some polishing! :thumbsup:
    MaxPete, GLJ and Moabite like this.
  18. GLJ
    Going to look less shiny. Getting ready to put the original tank back on.
  19. Jim
    Breathe deep the gathering gloom.... ;)
  20. GLJ
    Got a few things done this week. Painted top half of engine cases. Brushed it on. I sure it would be better to spray it on. Kind of like the rest of the bike. Looks good from 10 feet, up close not so much. It's on and I think it will stay.
    Replaced front and rear sprockets. I had a small oil leak coming from behind the left cover. Was expecting it to be the counter shaft sprocket leaking. It was bone dry on the backside of it. Clutch push rod seal looked good.
    Looked further. I knew the chain had been thrown on this engine. Case above sprocket was cracked/broke. What I hadn't noticed was how far the case was cracked. I have to be the luckiest guy on earth to own two XS2 engines with broken cases. Oh well.
    It was not a very big leak. After riding for an hour or so there would be 2 or 3 drops of oil under it the next morning. Decided I would try to slow it down or at least keep it from getting worse. This engine is coming out as soon as I get the original engine ready. Cleaned everything as good as I could with a brass wheel on the Dremel. Then hosed it down with brake clean followed by carb spray and compressed air. Then packed the cracks and bearing face with Yamabond 4. Since I have to go to Brampton for 5 days it will get plenty of time to cure.
    One last thing since I had squeezed out a bit too much Yamabond I decided to use it on the counter shaft sprocket even tho it didn't show any signs of leaking. I cleaned the shaft and spacer. Then filled the grooves of the splines. Put on the sprocket and lock tab. Then tightened it up. Shouldn't hurt any thing. My theory is the sprocket will push it in between the spacer and shaft. Also it should end up between the sprocket and spacer. I don't think the sprocket could push enough into the engine to cause any problems.
Share This Page
