My Yamaha XS650 Street tracker Build by olddude13
The first plate was bent on brake it dug in as it bent no biggie
You Can't tell but i did dress angle, And this time there is a radius and no crease.
Got speedo set right, taped my garmen to bars rode around yard. Rode home last night through metro park (no street lamps) Man those piaa's work great all most better than the lamp on my chopper build. It put my buddies 74 triumph's light to shame.
Finally GOT PAINT!!!! and coated pipes. will post more shots soon Gotta get take out food
Hey olddude,
so for your slip-fit muffler set up with the springs/anchors, do you use any sort of gasket material in the slip fitting? Or do you just slip it in, metal to metal, and put the springs on?
Thanks in advance!
I need to get my wife's good camera and if the sun comes out i will post better ones. here's what i have so far with my crappy camera. Special thanks to my painter Dave and pinstripe's by Kevin
This is prolly a stupid question but because of my aging memory......you have ridden this, yes? The reason I ask is 'cause it looks like you've got a 34 tooth rear sprocket. With the same setup on mine (34 tooth with a 19" rear wheel) I've gotta damn near slip the clutch leaving a stop and it's way too long legged in first. Have you noticed this? My front is a 17 tooth.
The bike looks great even the number board. :thumbsup: Like the paint. You nailed the look you were going for. Well planed build a show winner for shure. Thanks for showing your build. :cheers:
