Hi Guys,
I just picked up a '76 XS650. PO informed me that he was having battery charging issues. I pulled the cover today and had a look. He had a mikesxs pma system installed and it was not charging the battery at any RPM (12.4 at all rpms...). The mounting plate was broken and only held on by one screw though everything else looked OK. It appears that the PO installed the plate improperly and was unable to get it flush with the crank-case. Would this affect the stator output? Is it possible that the stator is finished? Obviously I need a new plate, but I'd like to avoid dropping $300 on a whole new kit.
Also, the bike was running a little rugged when I purchased. I pulled the vm-34 carbs and saw that the floats were sticking -- cleaned it all up and seemed to idle fine (though, didn't want to ride with no charge). Inside was a P6 needle jet, 25 pilot and a 160 main. Does this seem about right? Stock exhaust, k&n filter....
Lastly, has anyone made the side covers work with the vm-34's? PO had them off but I like the way they look. Any suggestions or pics?
Thanks!
Thanks!
