I may be new to this forum, but I have been welding frames since the early 70's, for road, race and trailbiking, i even built two dirt bike sidecars.
I started with stick ( all i could afford) raked a sportster and then went to O/A. I brazed race frames and with practice they looked like TIG, I used old O/A set and then got a better one, still used stick whenever it was convenient, tried Dillon (as it was then, it is called Henrob now i think) which was real good for exotics. I applied hardfacing with arc and O/A and O/P.
I learned and bought a TIG and finally these days use that and MIG (GAS GAS GAS!!!) mostly, though i still use stick as well. best quality right size rods are the secret to real neat stick arc welding where the scale falls off by itself as the weld cools.
I never had a frame fail in normal (race) use, or on the road or trail.
It is technique that is important, not the method. use what you are good at and can afford, but do not keep going on a job that you (or more importantly, others) do not have full confidence in, if that happens, stop and get help, dont just keep blasting to cover it up.
I am not trade qualified but have an engineering background and was taught OTJ by experts, which i am not. Frame welding that is structural in nature is critical and should be attempted only when you are confident that you can do the job properly. get someone who knows what they are doing to show you how and lots of practice and especially with smaller, individual, less important parts that can be replaced or re-done if you are not happy.
It's not hard, but at first it is not easy.
HD
