Sold / Found / Inactive - 35mm forks with tapered bearings and caliper
gggGary
If not now, When?
XS650.com Supporter
Baraboo, WI, USA
35mm fork set, looks real nice and clean, couple pits well above the swept area, sure they need seals, tapered bearings and caliper, every bolt is there, they plunge smoothly.
Brace is sold.
DSCN9485.JPG DSCN9484.JPG DSCN9481.JPG DSCN9482.JPG DSCN9483.JPG DSCN9480.JPG DSCN9473.JPG DSCN9471.JPG DSCN9470.JPG DSCN9472.JPG DSCN9476.JPG DSCN9474.JPG DSCN9479.JPG DSCN9475.JPG DSCN9477.JPG DSCN9478.JPG
Well I can tell by the witness marks the stock fender I got with it had been installed inside the brace, probably would rub a 110 tire...
Hey there Gary. I'm interested in the forks. Have a '75 I will be racing next season and I want to convert to 35mm front end. Can you give me a price including shipping to 40511? Thanks.
I'm not entirely sure what all I will need. But it is my understanding the 35mm forks and trees will work on my '75 frame. I plan on using the pandemonium kit to run a Brembo caliper. So I would need both fork legs, the triple trees (and bearings if you still have them). I don't know if I would need the axle and spacers and use my wheel or if I would need the wheel as well.
Here's what I'm starting with. A friend had this bike with no title.
OK then triples tapered bearings and upper/lower tubes is all you should need,
I'll look into this tomorrrow.
