For Sale - '83 XS650 Heritage Special
bdholsin
XS Enthusiast
Coleman, MI
Putting my '83 Heritage Special on the selling block. $1,500, ready to ride and clear title in hand. Rebuilt the engine during winter of 2011-2012. Runs good. All covers are present. Located in North Bradley, MI (half way between Sanford and Coleman). Cash is good, Paypal is fine too.
Just don't have time to ride and I'd like to use the cash for other hobbies/projects.
Here is what I've done since I acquired her:
1. Adjusted intake and exhaust valves
2. Adjusted cam chain tensioner
3. Rebuilt master cylinder
4. Replaced seals (main sprocket seal, clutch pushrod shaft and kick shaft)
5. Replaced starter gear
6. Upgraded clutch needle bearing
7. Secured tachometer and speedometer
8. New battery
9. New ignition coil
10. New plugs, wires and boots
11. Upgraded clutch pushrod to one-piece design
12. New right & left cover gaskets
13. Replaced a few grommets for the decorative covers
14. Cleaned carbs, cleaned carbs and cleaned carbs
15. New air filters (pods)
16. Replaced numerous fasteners with allen head screws
17. Replaced oil sump filter
18. New oil filter
19. New oil
20. Added inline fuel filter
21. New mix screw o-rings and washers
22. Replaced crankcase breather gasket
23. Shortened crankcase breather tube and added breather filter
24. New starter to crankcase seal
25. New gaskets (drain plug crush, carb holder gaskets and tappet covers)
26. New starter brushes (didn't help the starter)
27. Fixed the odometer (wasn't advancing)
28. Fixed the tachometer face plate (screws came out)
29. Replaced rear brake switch
30. Added clutch lever bushing (reduced lever free play)
31. New cables (tachometer, speedometer, throttle and clutch)
32. Braided SS front brake line
33. Replaced stock fuse block with new automotive style blade block
34. New tires (@ 18,000 miles)
35. Swapped stock 34 tooth rear sprocket with 30 tooth rear sprocket
36. Removed one link from drive chain (result of 30 tooth rear sprocket)
37. Stepped the mains up one size to 135
38. Replaced swing arm zerk fittings
39. New clutch springs
40. Shot blasted carbs
41. New alternator brushes
42. Installed right hand mirror (helicoil)
43. New float, float needle and float needle seat (ordered 8/30/11)
44. Rebuilt engine (2012) @ ~18,352 miles
a. New piston rings
b. New connecting rods
c. All new seals (including valve seals) and gaskets
d. New clutch pushrod bushing
e. New cam chain
f. New cam chain tensioner and front guide
g. Valves lapped
45. New Headlight
