Scooterbrain
I have a mystery. On my 1970 XS 650 Resto, I am installing the advance plate on to the camshaft at the right side threaded end. I have the correct pin to place in the shaft to align the plate and I see the notch in the rear of the plate which will work nicely I suppose. Bike ran well when I tore it down and it had had the Alternator replaced with the 200 watt brush-less unit and a capacitor in place of the battery but still had the std ignition points in place.
The first issue is that someone "previous owner" has brazed a Pin to the rear side of the advance plate even with the slot and just about 3/16 in above it. It interfaces with nothing and I do not know why that was done. If installed it looks like it will interfere with nothing but it will be quite near the outer edge of the Camshaft seal. Does anyone know why that was done and if it will be an issue ?
Also I noticed that with the New seals " from Mikes XS " being half the thickness of the original ones, are just about even with the locating pin hole in the camshaft. I knocked the seals back so that they had really good contact with the camshaft But it still looks rather close to the locating pin hole in the shaft and I am leery of trying to knock them further back.
Any ideas anyone ?? Thank You !
