The thing is left to run for a few minutes, to get a good pencil trace on the degree strip.
What I'm looking for here is not only true TDC, but the size of the gaps in the pointer's up/down movements, which could be a measure of the connecting rod's clearances.
I'm working with the following assumptions:
My experience with piston/ring fitment in cylinder bores says that there's enuff stiction/drag there to not only hold the piston/rings in the bore, but to also support the weight of the connecting rod. I don't believe there's enuff stiction/drag to lift the heavy crank, effectively eliminating its main bearings from this analysis.
This gadget is only applying fore/aft forces to the fan board, eliminating any up/down forces that could move the crank up/down.
So, the only clearances I'm expecting to be revealed would be from the connecting rod small end (wristpin to conrod, piston to wristpin), and from its big end bearing.
The clearances at the small end's wristpin are so small, plus being oiled, should be non-detectable. Unless they're worn, which this thing should detect.
So, I'm expecting only big-end clearances to be detected by this thing.
This post #29 in gggGary's crankshaft thread shows what I'm expecting in the range of big-end clearances:
http://www.xs650.com/threads/crankshaft-split-overhaul-assembly.31213/page-2#post-523057
