Beck Built Fab 2 into 1 intakes
Beck Built Fab
Custom XS650 chopper parts!
Grand Mound, Wa
Hello all!! I wanted to announce that I am now offering 2 into 1 intakes! I have two material options at the moment, Polished Stainless and Raw Steel with the option of left or right side carb mounting. I will be adding some more options in the future such as Raw Stainless and powder coating options.
All flanges are laser cut out of 1/4" material. Stainless intakes are all 100% back purged so there is no "sugaring" on the inside of the tubes thus no restriction of flow.
I am open to doing some custom intakes but am limited by the availability of material and those will obviously be a bit more expensive than the standard ones.
I have now launched an online store where you can place orders! Feel free to ask any questions!
Also I will be adding more parts to the shop as I grow. At the moment I am developing a steel horseshoe electronics box built around an 8 cell antigravity battery. It will be large enough to house the battery, a small fuse block, regulator/rectifier, starter solenoid, flasher relay and the stock TCI box. I am also going to be offering full stainless shotgun style chopper exhausts.
Check out my shop here!
Beckbuiltfab.bigcartel.com
Hope to work with some of y'all soon!
What's up everyone!! Just popping in to let everyone know that I am getting a jump start on my 4th of July sale for my 2-1 intakes!
From now until the 4th of July all intakes will be 10% off!! Just enter the promo code at checkout for whichever material you want!
Raw steel is - BBF10
Polished Stainless is - BBFSS
I've done a 1 into 4 (or 4 into 1, depending on your point of view) conversion for a 1982 Goldwing as I was tired of trying to get all four carbs to pay well with each other. The fabricator/vendor for the kit included a VW Beetle compatible carburetor with the manifold. While I am sure the performance isn't as good as a well-tuned quad, it works good enough. Starts right up, idles great, cruises great, and enough oomph to accelerate safely in traffic or on a back road.
What carb do you recommend with your 2 into 1? I assume there is a test bike running a prototype.
Rich Reed
Woodinville, WA USA
Rich Reed
Woodinville, WA USA
That sounds cool!!!
I recommend a Mikuni VM34 or VM36
I started a formal investigation into why the package has been in the same facility in Canada for over a month now, awaiting for “return to sender” best thing I ever did; as they have all of a sudden created a label for it to be shipped back to Seattle, fingers crossed!
Good to hear!!!
Good to hear!!!
Like I said fingers crossed, when I first learned of the screw up I watched the tracking info for 5 weeks and nothing changed, I went to the post office 3 times during this period and all they could say is we are seeing the same tracking info that you are seeing. That’s when I did more investigation and found a back door into launching an investigation into its whereabouts.
By the way my building permit has been put into limbo again (what a month)! so I should have time to get the xs motor into my Cheney frame and get some measurements for you so; we will be able to get started on the next piece of artwork from you; my new pipes!
Man, sounds like a nightmare! Glad to hear something may be happening with it though! Ok cool! I'm excited to get these pipes going! Thank you for the kind words!
Only 2 more days left on this sale to grab one of these 2-1 intakes!
10% off until 4th of July!
Enter code at check out:
Polished Stainless - BBFSS
Raw Steel - BBF10
