put em on a peg board hook (or any wire) heat reddish with a torch, done.View attachment 256087
Finally Found the New Ones!
But just wondering, and maybe to ask it is to answer it, could these be reused without annealing them? They are pretty thick....
I read here somewhere that they need to be quenched in water after heating...put em on a peg board hook (or any wire) heat reddish with a torch, done.
With copper quenching doesn't matter.I read here somewhere that they need to be quenched in water after heating...
Thank you Jim. I didn't want to make a huge back and forth and your explanation covers all sides. Particularly for those of us who got it red hot but forgot to get a cup of water to dunk it in. You are a gem here.Brass is one of those metals that'll anneal naturally or by quenching. There's a name for it but it escapes me right now....
Quenching in water does the better job of annealing, but only just. both will work just fine for all practical purposes.
I see that, somehow, brass became copper...not that it matters, but they're not the same thing. FWIW I doubt that the objects are brass by much. And yeah, heat and quench reuse if they're not cracked - use magnifying glass. The wiki has fair entry under "brass". Sheet copper turns up sometimes, if your eyes fall upon some, get it. With a bit of creativity it's punchable and handy. Mrs North found some at the junkstore! (it went into my electrical junk boxes)
Indeed so. Cu 100% ahbetcha. Still, what you want and what you get...manufacturer may not care...yeah fleabay or aliexpress.........
Copper's better suited to the job, and I think what those Zooky washers are made of, so the change?
Depends... if it's the crush type (most common), all you can do is replace it.While on the subject, How about the copper sealing washers for the large oil drain plugs?
They are rather large and I can't get all of it under a torch at the same time. Just work my way around them getting read hot and don't quench?
I'm going to have to try this out of curiosity. I even have a roll of that evil lead based solder at home.Once or twice on oddball industrial machinery where production costs were urgent, I have tinned over the copper with lead/tin solder...if one does this it's important to remember tin creep, re-tighten the next day or two. But for practical purposes a little gasket substitute loctite and away we go...
Is 10x22x2mm the right ones?I bought the Suzuki copper washers for my '78 years ago but eventually found much cheaper ones on eBay so that's what I use now .....
https://www.ebay.com/itm/155166672311?var=455348255804
copper was mis-id'd as brassI see that, somehow, brass became copper...not that it matters, but they're not the same thing. FWIW I doubt that the objects are brass by much. And yeah, heat and quench reuse if they're not cracked - use magnifying glass. The wiki has fair entry under "brass". Sheet copper turns up sometimes, if your eyes fall upon some, get it. With a bit of creativity it's punchable and handy. Mrs North found some at the junkstore! (it went into my electrical junk boxes)
