madjap
Anybody ever have a plastic float fail?
Yah I had to play with my float height as well supposed to be 24mm on mine if memory serves me correctly .... but it was a tad High
I finally hooked a piece of vinyl hose to the bowl drain and opened the drain screw and held the hose up along side the float to see with my EYE where the level was ..... it was right at the bottom of the carb body and top edge of the float bowl ! .....
I checked the other side and it was off a bit so I adjusted it to match the other side now they both are identical and the beast runs fantastically ! ..... that is one place that can be off quite a bit by using stock settings I found ! there was a tad more than 1/4" difference between them and they were both set at 24MM..... evidently the needle seats are purty crummy on the one carb ! LOL
....that hose trick helps identify goofie float levels fast ! it doesn't do a thing for leaky carbs though ! the float level is supposed to be very critical on these carbs so Make darn sure you have the right settings for your carb .... I went through the tech section skim reading and got 3 different float levels ! but they are for different year bikes !!!!!!
5Twins set me straight on the float level as I was using the wrong one ! ( par for the course for me !) LOL
but finally got it right and havn't had the carbs off sense !
Bob........
They don't need to be super tight to seal. Their lifetime seems to go like 1. just snug. 2. become so tight can't remove seat w/o damage. 3. become so loose they just fall out.They seemed to fit OK, but not SUPER tight. Gotta check em I guess...
Yes gggG. New lines, new fuel T, filter. Someone at some point 'shaved' these floats it looks like for a fitment issue? That wouldn't cause them to saturate would it? Foam floats, sorry.Always gotta ask; all new fuel lines, right?
seems like a good call xjwmx, AFAIK the foam floats should fit right in the brass float bowls, but I'll check and report.If somebody actually had to whittle on them to make them fit, the problem is they're the wrong floats.
When I turn on the petcock, once the bowls fill, they don't stop and gas starts pouring out the backs of each carb. Done the shaking thing, SOUNDS like they are jumping around in there. I am STUMPED. I'll wait and try these new floats once they get here and see if I can make it work. Something is not right. But I'll be damned if I can figure it out. I had these off, mounted on a board in a vise for level, set everything to the T. It's a good thing I take anti-FURY pills nowdays. These motherfuggers would have been unrecognizable by now - had this been 10 years ago. I'm just stumped. I have literally pulled these carbs 10 or 11 times and now have dropped the bowls and floats on the bike another 15 or so...without having the stock OEM floats to compare to it's kind'a hard to make a judgment on them....
However if they worked once , Float fine then there is something else going on.... What exactly is the problem now ? still getting overflow from the carbs or what ?
...... Also...if their not OEM floats then you can throw out the OEM settings for float height ... concentrate on one carb and get the fuel level up to the top of the bowls with the float setting by adjusting the tang.... then do the other side.
.... it sounds like the floats may be rubbing on the float bowl and jambing up ...if you can shake the carbs and not hear the floats slap back and forth their rubbing and will not work correctly...
Bob.......
