Jtporter9
JT
Okay guys so super confused here. So if you look at the picture below you can see the master chain link, and also the arrow which is next to the marker that indicates where the master chain should be (when at top dead center, and then the marker is in the middle pointing up) . I know I'm not at top dead center. But I took to picture like this because the master link is 3-4 places off from where the master chain link should be. (which is above marker. So when I put my engine back together I should get it where it should be...This all sounds correct right?
Well thats what I'm thinking is right, the only thing is that my bike was running like this, and not too poorly either. Not perfect, but not poorly. Anyways my question is should I move the master chain to the indicated spot marked on the cam? or should I put it back exactly how it was??? Super lost here. Any advice would be great!
Also what are the consequences if I do put the chain in the wrong spot on the cam??
Is it possible my cam chain was previously messed with and the chain dropped, then was put on crooked?? The only reason I could see it being okay as it is, is because when the maker on the cam is facing up it is also at TDC. Anyways, fire away. lets hear what you think.
