Cam chain guide is broken, the plastic has separated from the metal and is making some noise, so I have the engine apart.
I've seen tutorials that when the pistons are at TDC, the cam chain master link is, or should be at the top of the cam gear. My chain does not seem to have any kind of link that looks different from the other links at the top of the gear. Is this normal?
The chain I am installing has a master link that you rivet the pins on, so wouldn't my new chain also not have a visually obvious master link once installed?
Also, why is it important to have the master link line up with the top notch on the cam shaft gear?
Thanks.
Thanks.
