Camchain noise
Gray
Uk
Hi guys, does anyone have any information about cam chain tensioner problems on a 1976 xs650? I have a strange rattle I can’t trace
teamWicked
Amatuer
Sheboygan, WI
Look in the Tech section. Remove the tensioner cap (bolt) and tensioner rod should move approximately 1mm.
5twins
XS650 Guru
You can't get them new any more so I usually watch eBay for one. All you really need is the lock nut and the plunger but you don't see them listed separately very often. But if you're patient, you can usually get a whole assembly for around $20. Not too bad for (in my opinion) a much needed upgrade.
Gray
Uk
By the way, do you know if the copper washer for the type D tensioner is available?
5twins
XS650 Guru
Not from Yamaha, you'll have to go "generic", lol. I found some on eBay.
https://www.ebay.com/itm/124926667303?var=426003386240&hash=item1d1635aa27:g:VhAAAOSw7-FhUyO3
