cshumway
So I installed my Pamco (14-0911) correctly and my 78 special fired up first kick! I set the timing. But for some reason I cannot get the bike to stay running for very long? Before putting the pamco on I adjusted my valves, cam chain, full battery, and cleaned my BS38 carbs. Just today I started her up, she went to about 3000 rpms, rpms started to drop to 2grand and then it just stalled. I can't start it back up immediately, I have to wait a few minutes and she will start again, and then the same thing. I have tried adjusting the mixture screw on the left carb but that doesn't seem to help. I have the throttle stop screw a couple turns from bottoming out (Is that a normal place for it?). So basically it hangs at high rpms for a few minutes then just rapidly dies. My battery voltage is up over 12v after it dies. New brushes on the ALT, Factory jetting. One time when the RPMs were up I put it into gear and it died as soon as I did. My advance pops back like that video floating around. I'm at wits end here. Oh and I also have the Radio Shack retifier. I've tried leaving the gas cap open, same results. I cannot get the Idle to just hang out at 1200 rpms. It only backfired one time through the carb and one time through the exhaust (left side only) but that was when I was really messing with the idle mix screws. Is this a sync issue? Please some insight on what to do next...I know that the weather is sh*t here in Ohio ONLY because my bike isn't running.
Thanks all
Thanks all
